Re: International SA
Posted by Kennebunksawmill on November 27, 2009 at 13:36:43 from (74.69.237.149):
In Reply to: Re: International SA posted by Janicholson on November 27, 2009 at 12:51:49:
Is this common? Will this likely correct itself w/ a little run time? This is not one of our work tractors, we use it occassionally to pull a wagon & mostly for local parades (might see 20hrs a yr of use)...still, we religiously change all the fluids once a yr (motor oil/gear lube/ antifreeze flush)...I just did the yrly service, I use Napa 80-90W for gear lube....is this harmful to run in current condition ...or is it no big deal? One in gear, it runs 100%...thanks
