Re: md compression
Posted by D Slater on November 27, 2009 at 15:37:31 from (72.65.155.239):
In Reply to: Re: md compression posted by sven on November 27, 2009 at 13:53:50:
Pressures IH gives are for a running engine checking one at a time. If you did them with one injector out at a time on the diesel side with the starter. It would turn to slow to tell much. If you had all injectors out and used the starter to check it sounds to low. Would check to make sure starting valves linkage is letting them close all the way. Check starting valves for sticking bent or bad since that can be done during tear down for the low compression if needed. Leaking injectors can cause the problem you mention also.
