Hey Pete, If it`s the worm gear wheel that`s chipped, you can lift it off the shaft, turn it 180 degrees,put it back on and it`ll work great.That side of the worm gear wheel was unused.If it needs to be replaced, the shaft and gear from a C thru 240 will work fine , and I suggest changing both the shaft and worm gear wheel as a set because there were 2 different worm gear wheels that could be on there depending if it was a widefront or narrow front from the factory.One was 38 tooth(NF), other was 44 tooth(WF). Hope this helps and let us know how it works out, Mark
This post was edited by Mark Peters at 17:15:19 11/27/09.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
