Re: Need Wiring Help
Posted by jeffalex2 on November 27, 2009 at 17:47:13 from (71.246.94.148):
In Reply to: Need Wiring Help posted by Jon Young on November 27, 2009 at 14:50:47:
One of the most common mistakes made when rewiring a tractor is crossing up polarity and remembering if you're working with pos or neg ground. The spark and ammeter are indications of a direct short. Be careful, under those conditions, you can quickly destroy components or even cause a fire or explosion.
Assuming you have a wiring diagram and a PROPERLY color coded harness, double check everything. I've run into 2 wiring harnesses where the colors matched the diagram, but for the wrong wires. If it looks good as is, then your harness is not coded right. Hopefully you find an error. If the harness is wrong, you can still use it, you just have to recode it yourself. Use the diagram and an ohm meter to determine which wires are which and label them with pieces of masking tape.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
