Re: Farmall 706 Gas
Posted by Jeff Champlin on November 27, 2009 at 17:54:43 from (75.237.104.89):
In Reply to: Farmall 706 Gas posted by Time ou kid on November 27, 2009 at 16:44:22:
Just bought a 1965 706 for $4500. Has two point that I switched for the three point for $500. 400 hrs on rebuilt motor, all fluids changed tires in very good condition. Tractor is in great shape overall. noe welds in the front axles. TA works great. Yours with no TA will cut the value quite a bit. Hope this helps.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
