Re: Stuck in one gear
Posted by NEKS on November 27, 2009 at 20:19:47 from (208.69.238.232):
In Reply to: Stuck in one gear posted by Paul Klankowski on November 27, 2009 at 17:53:38:
Was using a 46 M Farmall clipping a field of clover with a frail cutter and shifted out of 4th into neutral fast to keep the cutter running. The rail slipped on in to 5th gear and that brought everything to a halt. It was a hot July day and over two miles from home. I was young so it was walk home or fix it (happened 51 years ago). Took shifter out and and used a rod and lined up the rails. You could set shifter in 5th gear spot and bring it back to neutral.
