Re: ? about fixing up Super M motor
Posted by James Rumph on November 28, 2009 at 04:12:59 from (24.192.125.175):
In Reply to: ? about fixing up Super M motor posted by Andy in IL on November 27, 2009 at 19:15:20:
Put the 450 kit in ! It will take you from 264 to 281 cu inch. Leave the stock cam in there it works fine.
Spend the money on the cylinder head this is ware you will get your gains.
I put a good 281 together a few years back with the stock cam and had it in the 70s on hp.
I run a dyno service so these #s are accurate. Don't go over 1800 rpm , you run out of cam.
The only real differance i made was a 450 "gas" head because it gave higher compression.
Make the normal improvments like a good "hot" coil , rebuild the distribuator with light springs to get the advance in fast. [ chevy springs]
Set timing with digital timing light with tach in it, go for highest rpm when setting timing.
A good rebuild on carb,"NOT SOME TRACTOR SUPPLY REBUILD KIT" a factory rebuild kit or send it out.
Keep it simple but pay attention to detail.
Gasket match everything.
If you find a 450 head there are a few small changes to be made in order to use it. You will be asking them when you go to hook things up.
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
