Re: Will this work
Posted by gene bender on November 28, 2009 at 07:25:59 from (67.55.226.179):
In Reply to: Will this work posted by chad from michigan on November 28, 2009 at 05:49:26:
The 100 should have close to 10gal but the problem is ground speed. You need the reduction gear for the C ub that Howard nade they are very hard to find. The shop that converted the Bs in Wi for the Gensing crops had a reduction gear in the tourqe tube real neat set-up but i cant find out where they got the gear-box. The shift lever was back by the tranny and the linkage went to one of the threaded holes on the left side below the gas tank they just used one of the threaded holes. I do have some pics of the linkage but didnt look in the tube to see the gear=box. Sure would be neat to have one.
