Re: Need Wiring Help
Posted by Janicholson on November 28, 2009 at 13:27:02 from (64.61.211.164):
In Reply to: Need Wiring Help posted by Jon Young on November 27, 2009 at 14:50:47:
We really need to know if it is using a generator, alternator, or non stock alternator. If an alternator, remove the wires from it and see if it discharges as before. if not, the ground polarity of the battery might be wrong alternators are almost always negative ground. The fact that the amp gauge went to D is an indication that there is either a short to ground from wiring, or a short to ground through alternator diodes with the battery in backwards. Let us know. JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
