Re: Air bound M
Posted by Dellbertt on November 28, 2009 at 17:39:28 from (209.172.22.165):
In Reply to: Air bound M posted by Dougie94 on November 28, 2009 at 14:42:26:
Dougie,
I have had inline filters in every tractor I have owned for the last 20 years, 300U, H, JDA, Case B, Cub, SA and they all run just fine.
About half the people on this forum use them and half don't, so make up your own mind. It is an ongoing, and tiresome debate. Do a search on the archives and you will find many posts.
Tell your auto parts dealer that you want a filter for a gravity fed system and they should give you the correct filter.
The symptoms that you discribe can be caused by several things including having a non gravity type filter.
Make sure you have a filter made for gravity system and you can eliminate that as your problem.
Dell
