Re: Need Wiring Help
Posted by JakeF on November 28, 2009 at 18:46:12 from (216.215.19.6):
In Reply to: Need Wiring Help posted by Jon Young on November 27, 2009 at 14:50:47:
Take your test light and hook it between the the battery and the cable. Hook the ground cable up. If there is any draw on the system the light will glow. Now start unhooking one thing at a time starting with the alternator, or the voltage regulator/generator. Then the ignition, headlights, ect. With the test light hooked in series on the cable you wont have the amp draw to hurt anything and even if you accidentally short a hot wire out to ground it will just ground out a small load and turn on the light.
When you find the problem the light will go out. It's much easier on a car or newer tractor as all you have to do is pull fuses, but many more. Just remember on a car or newer tractor you have to pull the radio/clock fuse, dome light, hood lights to get rid of all the normal parasitic draws.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
