Re: Will this work
Posted by mkirsch on November 28, 2009 at 21:37:16 from (64.80.108.56):
In Reply to: Will this work posted by Guy Fay on November 28, 2009 at 05:49:26:
chad from michigan said: (quoted from post at 08:26:21 11/28/09) well you could just idle the tractor and the live hydraulics would still turn the ground.
It would be on worked up ground basicly taking out weeds between rows
Nope, you need RPMs to generate enough pressure to turn the rototiller. Otherwise the tiller will just stall, even in loose sandy soil.
If you rev the tractor up, it will simply go too fast to do a good job. I suppose you can ride the brakes and slip the clutch, but that's hard on you and the tractor.
