Re: Air bound M
Posted by James Rumph on November 29, 2009 at 04:43:07 from (24.192.125.175):
In Reply to: Air bound M posted by Dougie94 on November 28, 2009 at 14:42:26:
Automotive fuel filters are designed to work with fuel presure , you have a gravity feed system.....
It will work fine with a small electric fuel pump that you can regulate the fuel presure down around 5 psi.
I run a fuel filter on my Super M but it is set up for tractor pulling and it has a large pump.
I used a fuel filter for a atv on my cub and it works fine. The atvs are gravity feed and the cub sips fuel so in this application it works fine.
I don't think you would get the fuel flow with one of these on a "M" .
Sounds like it's time for a new sediment bowl and carb screen.
