Re: How can I prevent/reverse flash rust?
Posted by mattofvinings on November 29, 2009 at 10:24:08 from (74.60.202.15):
In Reply to: How can I prevent/reverse flash rust? posted by Mike CA on November 29, 2009 at 10:14:50:
Couple things...put in welding rod oven, the low dry electric heat should drive off any moisture.
Also you could douse it with something like LPS2, LPS3 or Boeshield. Motor oil is also a possibility. If it is to be painted you can solvent-clean it back to good condition.
