Re: 1086 batteries loosing charge
Posted by pete 23 on November 29, 2009 at 11:47:21 from (173.87.147.73):
In Reply to: Re: 1086 batteries loosing charge posted by Don Rush on November 28, 2009 at 07:44:11:
Good to hear you found the problem. One of the things I do when I assamble one of these alternators is to check current flow through the field circuit. If you have an alternator with the internal resistor autos use for the tellite, you will get a current flow through the number one terminal with out voltage applied to number two, however, if you have the alternator normally used on tractors, you will not get any flow through field until you apply voltage to number two terminal to turn the regulator on. That is why some vehicles will run the battery down if wires are reversed and others won't, although if reversed your voltage regulation will be affected. I no longer have a test bench to test alternator output until I mount in on tractor so this is just an indicator for me that I do indeed have basic exciting circuit that should work.
