Re: How can I prevent/reverse flash rust?
Posted by GordoSD on November 29, 2009 at 17:03:38 from (216.106.242.131):
In Reply to: How can I prevent/reverse flash rust? posted by Mike CA on November 29, 2009 at 10:14:50:
Blow dry with the air gun when it comes out. Then smooth up the outer facing visible portions with a 120 grit flap wheel on your angle grinder.
Then spray it with the Cast Blast we discussed.
If you don't have these items you shouldn't have put it in the tank. But you can spray it with WD-40, and then take that off later.
You have to think ahead when you launch off into a new project. That's your greatest misgiving in this restoration. You are good at tearing it apart, but not ready to finish the step. You have about ten half done items baking right now.
Gordo
