Re: 460 power steering
Posted by CNKS on March 07, 2009 at 18:01:30 from (216.144.104.128):
In Reply to: Re: 460 power steering posted by mattofvinings on March 07, 2009 at 15:53:59:
Thanks -- My concern about the worm gear oil is that it is contaminating the Hytran as there is no seal between the gear box and the power steering unit, at least not that I have found. I wonder if I shouldn't just use Hytran in the whole thing? The manual is rather vague on that. I am also hesitant to replace a vented plug, but since it is already leaking, there is nothing in the unit to damage except maybe to cause a bigger leak, which ultimately may come out the top of the steering column, but I don't think so. The unit has no springs, it does have a spool, the oil is directed left or right to the piston (which is connected to the rack) by the plungers and spool in the valve block. That is my oversimplified explanation, anyway. One thing I did not mention. This problem did not start until I hung a bush hog on the fast hitch after adjusting the Tel-a-depth so that it worked properly. It did not leak by just raising and lowering the empty fast hitch. That was before I realized that the previous owner had plugged the hole in the cap on the main reservoir -- but, the lift works fine. The PS pump on the 460 is mounted on the main hydraulic pump. The power steering works fine too, except for more pressure turned fully to the right. Not sure how all this ties together as to what pressure goes where.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
