Re: How am I going to get this home?
Posted by Wardner on November 29, 2009 at 19:36:07 from (4.154.242.43):
In Reply to: How am I going to get this home? posted by tractorsam on November 29, 2009 at 17:48:10:
If you take the front bumper off, you will see the crank hole in the bolster. The crank itself is like a WD-9 crank but several inshes longer. They can be extended with a sleeve. Don't think it is a good idea to use a pipe wrench. You will just mangle the roll pin.
I just freed up a W-400 LP with a long soak using PB Blaster, a 12' lever on the left wheel, and the starter. It runs perfectly now.
