Re: Slime Tire Sealant
Posted by billde on November 30, 2009 at 04:59:58 from (72.26.89.156):
In Reply to: Slime Tire Sealant posted by Janicholson on November 29, 2009 at 20:47:32:
Melvin Ware said: (quoted from post at 21:47:32 11/29/09) I use a Farmall M for bush hogging pastures and constantly have problems with my front tires being punctured by honey locust thorns. Was wondering if the "Green Slime" product I've seen advertised would be of any help in sealing off such punctures? (www.slime.com) I am running tubes in both front tires. Has anyone tried this on tractor tires/tubes and if so, how well did it work? Are there any disadvantages? In the meantime I'm applying herbicide to try and eliminate the honey locust problem.
The best sealant I have used comes from John deere, you can get it in gallon pump jugs or grease tubes. Just keep the container hidden so your friends won't know you've gone over to the Dark Side :oops:
