Re: How am I going to get this home?
Posted by Wardner on November 30, 2009 at 08:24:45 from (4.154.242.48):
In Reply to: Re: How am I going to get this home? posted by tractorsam on November 29, 2009 at 19:08:45:
If the owner has a tractor and winch, you are all set. Of course, you will need a trailer bigger than a landscape trailer.
Park the winch tractor behind the W-450. Block wheels on truck, trailer, and winch tractor. Run the cable under W-450 to center of trailer front. Run it through a snatch block and back to pin on W-450 bumper. If it doesn't move, put another snatch block on bumper pin and run cable back to trailer front. You can "steer" the W-450 by moving the end of slack cable from side to side or center of trailer.
You will probably save yourself several hundred dollars.
This all presumes that the tires can hold air for a few minutes. Flat tires will not track very well.
