Re: How am I going to get this home?
Posted by Wardner on November 30, 2009 at 13:08:00 from (4.154.242.48):
In Reply to: Re: How am I going to get this home? posted by LarryM on November 30, 2009 at 12:39:32:
I guess you have never pulled a "Brake Shaft" on a H, M or later tractor such as this 450. The brake shaft is the bull pinion gear. It doesn't come out like an axle on a full floating truck rear end.
But yes, loosen the five bolts per side on the brake housings. Loose enough so the lock washers spin. I had to do the same thing to my W-400.
The tractor is probably in neutral as it appears to be on level ground.
If it is in 1st, 3rd, or 5th, remove the belt pulley delete plate and beat or pry the rail that is positioned forward. Or remove the shaft tower and do it there. Before I did anything, I would have the owner nudge the tractor with his running tractor while I was trying to move the shift lever by hand.
