Re: Farmall 100, hydraulics question
Posted by 440roadrunner on November 30, 2009 at 14:01:33 from (76.178.187.6):
In Reply to: Farmall 100, hydraulics question posted by Gary Puckett on November 28, 2009 at 19:03:43:
OK, what is this a "single point", a "fast hitch", or just what?
IN this pic you can see that the long link from "the box" to the fender mount shaft is missing. If someone can give me an eye--to--eye length and show me what it looks like, I could make that. Also, what does the spring and the second pivot buried to the rear do?
third party image
Below, we see the rear shaft, so what does this make this unit? I have no idea what the extra piece welded to the shaft is. You can see there's a horrid drawbar someone "built"
third party image
Below we see the quadrant. What do these do? One is lift, the other equalize? The control rod for the right hand side lever is gone, so I"ll have to make one of those
third party image
Below, right side of "the box." If there's any linkage that belongs on there, , it's gone. Anything needed there?
third party image
The pump. Not much to say there, I guess
third party image
Below is the right front steering arm. Can you rotate these or heat / bend them to get them away from the tires?
third party image
This post was edited by 440roadrunner at 14:46:41 11/30/09.
