Hi...From the pictures, it looks like your tractor had a fast hitch on it at one time. I say that because the rear rockshaft (picture 2)is the type used on the tractor with a Fast Hitch. If you want to hook up the loader to the tractors hydraulic system (instead of the front mount pump) you would need a by-pass block. Picture 4 shows the hydraulic manifold and what you call the box (Touch Control Unit). The by-pass block fits between the box and the manifold. The rod that connects the rear rockshaft to the front left rockshaft(on the box) came in at least two types. One type used a spring to help absorb shock and that type was used with the Fast Hitch system The other rod type was similiar but without a spring. I see both types on Ebay all the time. The right front rockshaft was used to lift implements like a snowplow, front cultivators or planter.So linkage depended on the implementbeing used. Do the steering arms actually rub the tires? Are the tires too big? Is the steering arm bent already? If the arm isn't bent, I would not heat or bend it. Pete
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
