Re: Super MD parts
Posted by John - OH on November 30, 2009 at 17:34:23 from (76.2.225.0):
In Reply to: Super MD parts posted by Andrew Z on November 30, 2009 at 15:44:11:
Hastings sells the rings. You need to know what size the rings are (bore size and width, and if your top ring is a keystone). If memory serves me right my set was around $250.00. I think the gaskets are still available from you CIH dealer. If you can"t find what you need call Dave at Fairview Farm Supply (866.882.8880), he will treat you right.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
