Re: removing a piston from a 606 gas IH
Posted by El Toro on December 01, 2009 at 09:19:36 from (74.103.74.58):
In Reply to: Re: removing a piston from a 606 gas IH posted by gqjoe on December 01, 2009 at 06:21:06:
If that engine has sleeves you probably need to replace the sleeve & piston, but if it doesn't have a sleeve that cylinder probably needs to bored oversize. Its a lot of work to to fix one cylinder and while you have it apart do a complete rebuild. You probably need to have that crankshaft measured for wear too. If you just do a patch job you will be tearing that engine down later. Hal
