Re: removing a piston from a 606 gas IH
Posted by El Toro on December 01, 2009 at 09:26:39 from (74.103.74.58):
In Reply to: Re: removing a piston from a 606 gas IH posted by gqjoe on December 01, 2009 at 06:21:06:
If there's a ridge at the top of that cylinder you will need to use a ridge reamer. Since it sounds worn you may be able to remove the piston and connecting rod. Remove the oil pan after draining the oil. Unbolt the rod cap and push on the connecting rod with the handle of a hammer and your piston should slide out. Hal
