Re: Broken bolts, stripped threads, etc.
Posted by CNKS on December 03, 2009 at 17:51:05 from (216.144.104.128):
In Reply to: Broken bolts, stripped threads, etc. posted by DRC on December 03, 2009 at 17:26:09:
For the Cub, don't have the specs for the SC, but the book says 20-30 ft lbs, I doubt if the SC is different. I will usually use new bolts if suspect and run a tap in the holes. IF the bolt is not broken, you might still get by with tapping to the same size and using a new bolt.
