if it starts good now i dont believe you would see any difference in the cranking.so just go with the kiss system. i still would like to do an experiment for my own curiosity. install 2new 6v and check cranking rpm. then install 2 new 12v in paralell and check cranking rpm. what my question is if you put in 2 1000 amp 12v is the amps going to starter 1000 or 2000 amps. if you put in 2 6v with say 750 amps ea. that gives you 1500 amps. i am unsure if the 12volt paralell batts. stay at 1000 or double. i do know that 2volt crank faster than one 12v due to amps.somebody should be able to give an answer on this.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
