Posted by Jim Becker on December 04, 2009 at 11:05:28 from (173.57.141.22):
In Reply to: IH 1000 Loader on SAV posted by Bud W on December 03, 2009 at 13:06:47:
That loader on a Farmall 140 is supposed to be able to reach 4.7 inches below ground with a level bucket. Not sure how much that would be reduced on a 140 High Clear. Bucket would certainly touch the ground when tipped down a bit.
I would be more concerned about stability. Loaders and high clearance tractors just aren't a combination you see. This may be more hazardous going to shows (loading/unloading) than in use. You could set the wheels wider but then you increase the risk of something breaking. The IH manual specifies limits on how wide to set wheels with the loader.
The front mounting bracket has to be modified to use with the heavy duty front axle. The same modification would be required on a high clear tractor.
You really need to get the manual for the loader before you try to mount it on anything. The tire settings, front bracket modification and hydraulic connections are all covered. You can get the manual from Binder.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
