Re: Farmall A Project Pictures
Posted by ScottyHOMEy on December 04, 2009 at 15:19:37 from (70.105.227.22):
In Reply to: Re: Farmall A Project Pictures posted by redFarmallboy on December 04, 2009 at 14:42:54:
Those leaks and what not are worth chasin' down' fer sure, but she don't look bad as she is. I've got a BN all overhauled anddolled up (and it needed it), and A SuperC still in her faded original paint. Each has its attractions.
Just be careful about the sandblasting to either have the part away from the moving parts or seal them off well, because, even then, and despite your best precautions, that stuff will get into places you never imagined were there.
Sounds like a rewarding project, especially workin' with your dad.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
