Re: Farmall 100, hydraulics question
Posted by JG20601 on December 04, 2009 at 22:02:37 from (63.28.121.42):
In Reply to: Farmall 100, hydraulics question posted by 440roadrunner on November 28, 2009 at 19:03:43:
It looks to me that your tractor may have had the fasthitch system at one time. On the left side there is a shaft missing - you may be able to find one used the correct length.
On my tractor the left lever, closest to the speed lever, moves the shaft you are missing to raise or lower the implement. The right lever would adjust the pitch of the plow or raise the front cultivators.
The first thing is does the factory installed pump you showed work and move the arms?
And about the tire hitting the arm - does it do that on both sides?
Will try to get pics of my 140 system.
