Re: Primer and Final Coat Compatability
Posted by CNKS on December 05, 2009 at 12:48:41 from (216.144.104.128):
In Reply to: Primer and Final Coat Compatability posted by Tom in Iowa City on December 05, 2009 at 08:51:26:
Use 2 part epoxy as indicated in the Paint and Bodywork forum. There are virtually no topcoats that are not compatible with it. There is absolutely no better primer. But, be sure what you buy is true epoxy, not what some minor manufacturer claims. PPG or Dupont or Martin Senour. Apply the topcoat within the window -- the spec sheet will be on the companies website, if your supplier does not furnish one. Differs between brands.
This post was edited by CNKS at 12:52:42 12/05/09.
