Re: Primer and Final Coat Compatability
Posted by CNKS on December 05, 2009 at 13:02:29 from (216.144.104.128):
In Reply to: Re: Primer and Final Coat Compatability posted by Tom Fleming on December 05, 2009 at 09:10:07:
If not epoxy, then use what the spec sheet for the particular topcoat says. Cheaper paints give instructions on the can. Dupont, PPG, etc use most of that space for safety precautions. Epoxy is the only primer you can be assured that is compatible with most all topcoats. Otherwise there is no assurance that the topcoat won't lift.
