Re: Primer and Final Coat Compatability
Posted by Wardner on December 05, 2009 at 14:21:07 from (4.154.241.138):
In Reply to: Primer and Final Coat Compatability posted by Tom in Iowa City on December 05, 2009 at 08:51:26:
I suggest that you supply the sandblaster with the primer. Otherwise, he will most likely select something from his paint closet. But assuming that he does order your specified paint, he will certainly mark it up. Moreover, there will be no question as to who owns the leftover paint and you will probably find a use for it later.
Go to an autobody paint jobber and they will recommend a paint system that will meet your needs or requirements. If they don't suggest a catylized epoxy primer as one option, ask them why they passed on that product.
If the clerk doesn't seem knowledgeable, talk to the store manager or owner.
