Re: 706 oil pressure
Posted by Owen Aaland on December 05, 2009 at 16:08:54 from (65.165.246.148):
In Reply to: 706 oil pressure posted by tat on December 05, 2009 at 12:33:54:
The aluminum oil filter housings that used fiber relief valves often have problems with leakage. You need to inspect the valve disk to see if it is eroded and allowing oil to bypass. Later and replacement filter bases used metal disks and do not suffer the same problems.
