Re: Need new batteries for the 706
Posted by Owen Aaland on December 05, 2009 at 16:22:30 from (65.165.246.148):
In Reply to: Need new batteries for the 706 posted by Allan In NE on December 03, 2009 at 17:44:20:
TractormanNC said: (quoted from post at 23:56:27 12/03/09) Tractorsam is correct!
Tractorsam is correct but you will find that when comparing batteries that the six volt version of comparable batteries will have about twice the CCA rating as the twelve volt so that the total CCA,s available will be very similar whether you use two sixes or two twelves.
