Re: sleeve bores
Posted by Owen Aaland on December 05, 2009 at 16:26:51 from (65.165.246.148):
In Reply to: sleeve bores posted by Butch-Ia on December 05, 2009 at 05:49:36:
The sleeves in a C291 must the correct press fit. They are not held in place by the head gasket like the C221 and C263 but are a friction fit. They also need to be installed to the correct height above the block deck. They do not bottom in the counterbore in the block.
