Posted by El Toro on December 05, 2009 at 16:32:36 from (74.103.74.58):
In Reply to: 706 oil pressure posted by tat on December 05, 2009 at 12:33:54:
I think that 10-30 oil is too light when working a tractor. Your cam bearings may be getting worn too. I would switch to 30wt and try it. If you use it in the Winter install an engine heater. I had that problem on a Farmall A in 1976 after I restored the tractor and redid the tractor engine with a sleeve kit and new bearings. After I installed the plow and made several passes across the garden I noticed the oil pressure dropping. I had used 10-30 oil after the rebuild so I pulled out of the garden and drained the oil. Put in 30wt and never had anymore pressure problems. When we were on the farm we used 40wt in the H & C. Never had any engine problems up until 1953 when I was drafted and we had a 10-20 and it was 21 years old before the engine was overhauled. Still used 40wt oil in it too. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
