Re: Will a farmall super h run a New Holland super 717 ch...
Posted by Too Far Gone on December 05, 2009 at 17:02:47 from (67.221.197.94):
In Reply to: Will a farmall super h run a New Holland super 717 chopper? posted by Nothing runs like a deere on December 04, 2009 at 18:06:02:
No,Not if you want to get anything done.Use the H to pull it to the field,then put another tractor on it.Get in soft ground pulling that chopper with a wagon load of silage and You'll see.
