Re: Primer and Final Coat Compatability
Posted by El Toro on December 05, 2009 at 17:04:29 from (74.103.74.58):
In Reply to: Primer and Final Coat Compatability posted by Tom in Iowa City on December 05, 2009 at 08:51:26:
Whichever epoxy primer you choose I would use their paint for the finish coats. I would supply the primer as suggested since you should have some left over as long as he doesn't dump
the paint with hardener back in the left over paint. I think its better to spray the primer since it will cover the surface better and get it in the hard to get areas. Hal
