Posted by pete 23 on December 05, 2009 at 20:35:54 from (173.87.147.73):
In Reply to: sleeve bores posted by Butch-Ia on December 05, 2009 at 05:49:36:
The bore size is stamped on block just above the oil filter base and it will read 1 or 2 or 3 and not letters. They are numbered in line front to rear. You can get sleeves that will fit a bore sized 1 or 2 or sleeves that will fit 2 or 3 supposedly. However, like previous poster said, they are to be a heavy press fit and you should use a installer plate that will limit their depth into bock, they are prone to crack if pressed in until they contact the flange on the sleeve. Oversize sleeves are available also in case they don't fit properly. Sleeving an engine is not always a piece of cake.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
