Re: While we're discussing distillate
Posted by bc on December 05, 2009 at 21:42:34 from (69.149.214.27):
In Reply to: While we're discussing distillate posted by ScottyHOMEy on December 02, 2009 at 18:00:46:
Well I went out today and moved hay. The 2606 does have a counterweight on it hidden in back of the manifold.
However, it was freezing cold this morning and the counterweight was in the down position. I wonder if the spring is bad? I would think in the cold weather, the spring would tighten up and turn the flapper so it heats the manifold with the counterweight in the up position. With it below freezing, the spring just touches the stop maybe a 1/16" of an inch before the counterweight is all the way down. I would assume the spring just slides out the slot on the shaft sticking out. Thanks.
