Re: Will a Super H radiator work for a '44 H?
Posted by big_red_man on December 05, 2009 at 22:38:56 from (24.206.119.177):
In Reply to: Will a Super H radiator work for a '44 H? posted by Mike CA on December 05, 2009 at 21:40:53:
Mike, your H has a water pump. It also has a spring in/under the radiator cap and a rubber "gasket" that the spring holds onto the neck of your radiator. That is what provides the pressure.
