Re: Will a Super H radiator work for a '44 H?
Posted by rustyfarmall on December 06, 2009 at 05:43:42 from (209.152.78.140):
In Reply to: Will a Super H radiator work for a '44 H? posted by El Toro on December 05, 2009 at 21:40:53:
Mike, hope I get this straight. There is a very slight difference in the grill of an early, non-pressurized radiator H, and the grill of a later, pressurized radiator H.
The later, pressurized radiator will fit the early H, no problem, BUT, the early, non pressurized radiator will NOT fit the later H unless you change the grill also or at least modify it slightly, and it has nothing to do with the Dzus fasteners used on the early radiators.
The difference is the location of the radiator over-flow tube. The early style has that tube mounted up high, which requires a notch cut out of the filler neck opening in the grill. The later style radiator does not need that notch, so the filler neck opening on the later Hs and super Hs does not have it.
To make a long story short, the radiator from that super H will work just fine on YOUR H.
