Re: Starting and power
Posted by Jeff Z. on December 06, 2009 at 06:19:18 from (74.76.3.113):
In Reply to: Starting and power posted by EagleMI on December 06, 2009 at 06:09:54:
First it sounds like the needle valve in the carburetor is stuck open or the float has a hole in it and is not letting the needle valve close.
Clean the carburetor and install a new needle valve and seat.
Compression may also be low due to stuck rings in the pistons. If you get it running the rings will probably free up.
