Re: Seal on govenor housing on M
Posted by D Slater on December 06, 2009 at 08:45:56 from (72.65.147.198):
In Reply to: Seal on govenor housing on M posted by Linemanfarmer on December 06, 2009 at 07:39:34:
After governor housing is removed from tractor.
Remove housing cover, front arm that spring is hooked to and key from throttle shaft. Pull throttle shaft out and you can see the seal in housing. Not hard to do, 2 of the three 3/8 bolts that hold governor on engine screw into it from the front side of front cover.
