Re: 1944 m tractor no start 6 voilt
Posted by Dave H (MI) on December 06, 2009 at 11:31:21 from (64.12.116.73):
In Reply to: 1944 m tractor no start 6 voilt posted by R.J.M.T. on December 06, 2009 at 07:23:35:
How long has it been since you run through your wiring and connections? 6 volt systems simply don't do well if you have dirty or corroded contacts at key points in the system. This includes some grounds you may not think of like the mating surface of the starter. Most of my 6 volt troubles start there. Check your continuity from battery to starter with a meter and should be able to trace it down.
