Posted by Owen Aaland on December 06, 2009 at 12:55:14 from (65.165.246.148):
In Reply to: 2404 hydraulic pressure posted by theponyroper on December 05, 2009 at 22:53:43:
mic h 560 said: (quoted from post at 02:53:43 12/06/09) I have a 2404 and the hydraulics only have pressure when the 3 point I at the very top squeeling the pump as soon as u move the lever down enough so that pump stops squeeling the pressure drops to 0 psi. The result is the power steering doesn"t work. I was curious where is the pressure relief at and would that be what it sounds like? Thanks for any input.
The squeal you are hearing is the relief valve opening. The linkage must be adjusted wrong or you would not be able to put the system on high pressure with the hitch.
If you do not have steering unless the the system is forced to open the relief valve, your problem is with the priority flow divider valve for the steering. The valve should be the first place the oil goes to when it leaves the hydraulic pump. The valve should separate off about three gallons of flow for the power steering. The rest of the flow should go to the hitch and remote control valves if so equipped.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
