Re: 706 oil pressure update
Posted by Owen Aaland on December 06, 2009 at 13:08:27 from (65.165.246.148):
In Reply to: 706 oil pressure update posted by tat on December 06, 2009 at 11:51:56:
The block is bored for the oil passage in the center of the web from the main bearing up to the cam bearing. You should not be able to go back far enough to reach that hole.
There is a drain hole for the rear cam bearing near the back of the block. It is drilled at an angle. The bearing should not be so far back that it covers this hole. I have seen bearings installed so that the oil hole in the bearing is aligned with the drain hole instead of the hole coming from the crankshaft. I do not remember if that left the bearing covering the feed hole or not.
