Re: M tractor carburetor or governor
Posted by Andrew Z on December 06, 2009 at 14:40:29 from (64.252.130.179):
In Reply to: M tractor carburetor or governor posted by BRAD ENGLUND on December 06, 2009 at 14:15:16:
sounds like the shaft coming for them governor either is binding against the sides of the hosing (the sliver piece you see) or is not properly lined up with the carb slots. I would remove and clean like you think. spray some lube in there tri flow, pb, etc. make sure the shaft is lined up when installing.
Andrew
